nuttyboater
- Joined
- Jun 26, 2008
- 81
Here is the problem, when cranking she will pop every 1/2-3/4 turn of the flywheel, which disengages the starter, but it won't take off and run. So its crank pop, crank pop, crank pop.. I have been doing this over and over and over, with ample time for the starter to cool of course.
I replaced the plugs, four new Champion 77's, checked for spark on each cylinder with a tester set to .030, nice bright blue spark on each cylinder.
Pulled apart the fuel pump and the carb, all clean and working, the fuel bowl is filling up, and there is fuel flowing through the carb and into the engine because the plugs are wet after cranking. The carb was also rebuilt last year, it was ran in a barrel for about ten minutes and then run dry and stored back in the garage, and this is the first time i have put fuel back into it since i bought it, my stepmom didn't want to sell it back then but did this year.
The best i can tell is the mixture screws aren't right. I drove to a local shop last week and looked at their service manual, also called them today to verify, and they said to lightly seat the mixture screws and then back them out 1-1 1/2 turns and go from there. Problem is i can't get it running long enough to make any kind of adjustments.
Anyone got some better info on the mixture screws?? I have tried everything from closed to 3 turns open, in 1/8-1/4 turn increments. It won't start and continue running anywhere. As suggested by another mechanic i put gas in the carbs, been there done that before when rebuilding the carb's on snowblowers and lawnmowers so i knew the drill, but that doesn't help because then its flooded and takes a hell of a lot of cranking, or taking the plugs out and cranking, to get all the excess fuel out and get it popping again.
I have moved the throttle from idle to WOT and it doesn't make any difference in trying to start it.
At this point i'm just fed up and wanting to put a bullet through it, but before i do give me some suggestions because i'm out of ideas.
To Recap...
1. It has spark on all four cylinders, nice and bright blue, as tested with a spark tester.
2. It has fuel, took the carb and pump apart and they are flawlessly clean.
3. It has brand new freshly mixed fuel, 50:1.
4. Adjusting the mixture screws in and out doesn't seem to help any, moving the throttle while cranking doesn't help any. Oh, and the choke doesn't have any affect either.
The only thing i can think of is borrowing the gauge and doing another compression test, but it checked out before being stored last year.
To Recap...
