Emerald14
- Joined
- Feb 21, 2006
- 31
Hey fellas,<br /><br />1968 Evin 18hp #18803M-E02656<br />I discovered last evening that the No. 1 cylinder sparkplug is stripped on this motor that is new to me. Was using my trusty torque wrench set at the recommended in/lbs. converted to ft/lbs. Torqued the No. 2 cylinder first with no issue and the No. 1 cylinder never came tight. So, as a result, I pulled the head to repair the threads and am going to replace the thermostat, and gaskets. When examining the head cover, I noticed a port to the "port" side of the thermostat housing that is part of the water jacket. It is apporx. 5/16 to 1/4" in dia. It has a rubber plug inside. It didn't look like it belonged there and was wondering if it could have become dislogded from somewhere else and became lodged here. The rubber plug is approx. 3/8 to 1/2" long and appears to have been chewed up on the larger end.<br /><br />Any ideas??<br /><br />Thanks for your advice.<br /><br />JR
