Hi Everyone<br /><br />Installed water pump last weekend. At the time we thought the shaft going from motor to lower unit turned in both directions. That is we concluded the "transmission" was in the upper unit. We now know otherwise. <br /><br />At the time, we said if th shaft spins both directions and this part is rubber, then it doesn't matter which way the vanes are bent, it would correct itself each time. Are we half right, if it were installed incorrectly, would the vanes right themselves when motor is started?<br /><br />thank you <br />Billy Bob
