I have a 1968 Johnson 9.5 outboard that i've been working on. Done a bunch of cleanup on it to get it back on the water including the following for future reference:
Carb clean, new fuel pump, new fuel lines, new Impeller, Gearcase oil, new points, new condensers, cleaned and filed stator points of contact, new throttle link arm, new shifter link, cleaned plugs and tested spark (good spark) .... theres probably more but i can't think of it all off hand
Note: I have not tested compression, i don't have a reader but i've seafoamed to clean up as much carbon as possible to ensure i'm not losing compression due to that. The motor ran better in a barrel at home than on the water under load.
So, to get to the issue,,,, Motor starts up quick and easy, first or second pull and idles well (i noticed it idles with or without the choke) when I put it into gear it will allow me to putt along just fine at low speeds, when i give it too much throttle it seems to spike the RPMS and then completely lose RPM before choking itself out and dying. Generally speaking i've been able to start it back up right away after. It seems to run the same with or without the hood on, i don't suspect a exhaust leak but it's on my list for diagnostic.
The butterfly plate in the carb opens up at high speeds, as well as the high speed fuel jet seems to be pretty clear (I may check it again just out of crossing all my possibilities off)
Anyone have any suggestions as to what else I could start looking at or back-tracking towards if need be.
Thanks in advance! Tight lines and safe boating!
