68 merc 500 shift linkage
blacksmith04
Same old story. I replaced the water pump and now only have forward. So today I droped the lower leg and put the lower leg in reverse and the controls in same. went right in. only problem is that the controls are locked in reverse now. So I drop it again this time I put it in neutral. locked again. Droped a third time forward and forward. Now the controls move but will not shift gears in the lower leg.
So I droped it about 20 more times. Last time I had both in reverse it locked them up. Lost my head and forced it to go into neutral. Bad move. It caused the shift rod to pop up and hit the lower carb. Droped it agian and the rod goes back down and works untill I put the lower back in anything but forward. I need help.
