I am trying to remove the lower unit from a 1968 merc 650. Have removed all the bolts and nuts from front and rear (trim tab bolt, bolt under the trim tab and the nut under the mount), and loosened the two in the middle (they won't come off until the unit is free, not enough room). The long bolt at the front, under the mount, appears to be frozen inside the shaft. The lower unit flexes at all places except the front when I pry on it or use the two middle nuts to put pressure on it. I have used heat on the housing without effect. I've put the nut partially back on and hit it with a wood shaft and hammer without success. I have also soaked it with penetrating oil. What can I do next?
Thanks for any advice!
