I need to remove the bearing carrier from a 68 55hp evinrude electric shift to replace the retainer plate the threads are bad and getting water in the LU from it.
Now my question is how the hell am i getting it out? Book says use a puller with arms through the web of the carrier. Well the web is only on the top half of the carrier so its not letting me pull straight. I don't wanna bend the prop shaft or anything. Has anyone delt with this carrier before?
Also for the snap rings do I need a special truarc pliers or will a long set of needle nose work the same?
Thanks, this is my first time getting in depth with a LU besides oil and water pump.
