Crusty bottom
- Joined
- Jul 2, 2009
- 8
Long Post:
Hello All and thanks for a great site.
I have been boating/tinkering with small boat motors for quite some time and I am in need of some assitance.
Here is what I have,I recently purchaced a near mint 1969 starcraft Jupiter V. That being said it is powerd by a 1968 'Rude Triumph, eletro shift (model 55873R - SN J13099). The gentelman I brougth it from said it "runs, but when I shift it forward the motor bogs and dies I think its not getting enough fuel"(at this point I should have broght that bridge while I was at it). After I got the boat home and started poking around, I found that it has electrical probems.These are my observations:
Zip cord wire to aux spot light burnt,this is what led me down this troubleshooting path.
1. Starter will spin very good.
2. No spark at all cyl's.
3. Blocking diode, at console disconnected on one side(dont recall which side- Off the terminal board or terminal or on the shift wire connector.
3. All 3 wires on rectifier,damaged insulation/over heated/age
4. Elec choke works
5. "Run" Light works
6. "HOT" light works when I jumper it.
7. I hear the soleniods engage/disengage when I press the FNR switches with key ON.
8. Compression test will be done.
9.**** Found 2 wires that eventually go to the point plate burned.After inspection, found one wire goes to ground on the block and then to the ring that holds the points.The other wire attaches to another spot on the ring, forgot EXACTLY where it attached, but I belive it was attached to the insulated stand off that goes to the "ANTI REVERSE" Spring contact.the other end of that wire goes to a connector to a Black wire with white stripe comming out of the harness.
I refabricated the 2 wires with proper gauge/type and reattched to where they connected on the points ring( see last statement).
When I do a continuty test between the 2 wires(unattached to ground and black/white wire, I see a short(0 ohms).With the key "ON" I see 12v on that black wire with white stripe.
I have the wirining diagram for the motor(1959-1972 EVR/JOHN 3 , 4 , 6 cyl's, appendix A-12)
When I do a resitance test(20 ohm scale/digital meter)on the STATOR I get a reading of about 1.1-1.4 ohms.I dont see any "obvious bad" spots on the stator. ( just tourist info)
I will be replacing the regualtor- part on order-
MY QUESTIONS:
What I dont understand is the diagrams shows the black/white stripe wire as comming out of the amplifier,and it is shown as a DASHED LINE - WHAT IS THE SIGNIFICANCE OF THAT INDICATOR? And if it attaches to an insulated contact, Why do I see a dead short on the free ends of the wires? I suspect that if I rehook the wires "AS WAS" will I get the same result of burned wires? perhaps when I removed the components I lost a "part"??(it was getting dark and the end of a long day).
Thank you in advance for any guiadnce on how to move forward.
Joe
4. Elec choke works
MY QUESTIONS:
Joe
