69/115hydroelec.
horsefly38425
just got this one and have shift trouble if what i read is right it will only shift when bolted up and running /is there a way to ck lower for shift when it is off the motor/selonodes work but no neu/rev :confused:
lark2004
Re: 69/115hydroelec.
these units default to forward, and will only go to neutral/revese when the motor is running.
ddaigle
Other posters have stated that they have hooked a drill motor to the driveshaft and spun it to check function of LU. It doesn't take a lot of rpm as the starter motor spins it fast enough to function when starting the engine. Hope this helps.
ledgefinder
Ensign
I can get them to shift by turning the flywheel with a big ratchet (several complete revolutions), or certainly with the starter motor. Not sure this would work in all cases, but it has always worked for me (5 or 6 examples).
R.Johnson
Omc sell's a socket that fit's the upper drive shaft splines. I have used this socket with a speed wrench to turn the drive shaft while the gearcase is in the bench holding fixture. Of course you have the battery connected for this test. If the gearcase is correct, it take's very little RPM to shift.
horsefly38425
thanks i thought i could spiner with a drill but more??? the 2 rods that go in the nose of l/u one goes through the other /the lower/outside one has a clip on the end does it just sit down on the part that looks like the eye of a needle ? --next the smaller one that works off top selonode does it just sit down in there ? why i ask is someone has welded a lot on the nose /looks like there may be a bolt that goes in front /across i mean /i got rear/input/front gears out but front one has 4 slots /NEXT ?????
seahorse5
If fwd. gear is removed, all you have to do is pull the oil pump. It may be held in place with a tapered snap ring, similar to the ones in the rear of the gearcase. (don't get them mixed up). Them remove the oil screen and use 2 long threaded rods to rock and wiggle the pump housing out of the gearcase.
