69 1250 prop stuck on shaft
twkjr 1250
iremoved the nut and washer banged on back of badeswith 2x4 and hammer wont budge maybe original and froze on like alot of things am i missing something here
matt9923
Re: 69 1250 prop stuck on shaft
It should pop right off.... Check if theirs a c clip or something. It probably corroded together. I would soak it in a bucket of wd40 or something they sell gallon jugs. Be careful hitting the prop to hard.
Matt
Chris1956
Tilt motor up and put PB Blaster on splines and let her soak a couple of days. If that doesn't get it you will need to try puller followed by chistle.
matt9923
I have herd of someone tying one 1/2 the engine to a tree and pulling on the other with a truck. It worked but i wouldn't be doing that.
Matt
Karl_Childers
get an old fashioned, run of the mill, steering wheel puller. go to your local hardware store and get some threaded rod and a brass nut. bend the threaded rod into hook that you can wrap around the prop blades and run the other end through the puller. Use the brass nut inbetween the tip of the prop shaft and the puller so you don't damage the prop shaft. Set it all up and put some torque to it, while hammering from the backside with your 2x4 and BFH. While you are making up this puller, start soaking the whole thing down with PB Blaster as was said in a previous post. Next step might be the plasma cutter!! Been there done that. Good luck!
Rob
twkjr 1250
thanks guys she's a soaking is there such a tool as a prop puller other wise mcgyiver is going towork because im not cutting prop rather try some stop leak haha it is a salt water engine
matt9923
Salt water = bad on motor and you need to do a lot more maintenance. Newer ones are better in salt water with better seals and such.
GL Matt
cr2k
Yes there is such thing as a prop puller. Most likely any pulling may result in prop coming off hub. Then saw, or grind away rubber on hub to access the core sleeve on 2 side and carefully use thin blade cutoff wheel and cut ALMOST all the way thru on 2 sides (not to damage prop shaft) then chisel and BFH. This tells you why you pull the prop off annually and grease the propshaft, more often in that nasty salt water.
twkjr 1250
not my bad maintenance got this motor free and it was sitting on back of a boat under trees for over ten years any way got the prop off stood the wheel on two 4x6's and banged on the shaft came off pretty good however i wouldnt recomend this way i mushroomed the end of the shaft a bit nothing my grinder and time couldnt handle prop is back on , now i need to find upper water pump housing & heli coil one bolt hole for pump housing bolt does anyone have supplier for the upper water pump housing i looked and i looked somemore thanks again guys
