69' 25hp Evinrude Flush
tomh59
I realize that for most people just dunking a motor in the barrelto flush it is the
easiest. Not for me though. Could someone help me with the proper
clamp on type flusher and where I could locate one. I realize they may rare.
Thank you for viewing this.
tashasdaddy
Re: 69' 25hp Evinrude Flush
they are more scarce than hens teeth, and the needle in the haystack, put together. i've seen 2 on ebay in the last year. and are expensive when they come up.
HighTrim
That is almost as good as FRs "Fanged Chickens", which by the way I still have not found :)
tomh59
Somebody has one that they don't need. Come on gang!. I know it's out there. I have yet to see where anyone has been let down by this forum.
BoatBuoy
One person removed the long, narrow plate (first photo), and made a tracing of it. He then cut a same-size replacement with a large hole and a hose fitting welded/soldered to it. He then duct-taped up the screen (second photo) to prevent the water from running right back out. Claimed it worked well.
Be sure and don't obstruct the exhaust outlet behind the screen.
Also, these photos are from an older motor, but maybe you could adapt the technique to yours.
tomh59
Thank you. That's a good start. The pics are a great help as well.
HighTrim
These buckets are always easy as well.
tomh59
Another option. Who carries them? Just it case. It looks like it folds down.
HighTrim
Try out this link. Just an option if you want something that can be compacted, and act as an ice holder for the beer in the garage when ur not using it ;)
"http://cgi.ebay.ca/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEWAX:IT&item=290181849695&_trksid=p3984.cWAT.m240.lVI"
R.Johnson
I have posted several times on how to make the attachment Boat boy is showing. Easy to make, cheap, and work's better than any clip-on. You don't have to block off the other inlet to make this work, you will have more than enough water flow. My guess is that it is to cheap, and easy to try.
BoatBuoy
Mr. Johnson, Thanks for chiming in on this. I apologize, but I couldn't remember who's suggestion it was.
