Alrighty then...
Thanks to the crew here, I got the lower end resealed and issues all fixed! Also, rebuilt the fuel pump and the carb, and this is what's happening now:
1) It will NOT start in neutral, but starts with the first crank if the throttle is pushed forward some (gears not engaged of course). Even after warm up, will not idle in neutral and stalls. I screwed in the idle screw on the carb till seated and then turned CCW 7/8 turns, started it in throttle, and despite turning CCW or CW, it still wouldn't idle in neutral. I did notice that some fuel (very minimial amount) was dripping out from the carb out by where the choke shutter is... again very minimal (don't know if this is of any importance or relevance)
2) Runs great when in throttle from just past neutral to about 50% throttle... anything past 50%, it'll run for 10-20secs at best, and then seems to loose power... almost like surging, but never stalls. I crank it back down to about 50% or less, and viola, runs good. Adjustment of the idle screw on the carb didn't seem to change this much, of any.
Any thoughts, suggestions? Like I said, fuel pump rebuilt, carb rebuilt within past month, fresh gas/oil (almost done w/ the first 6 gallon 50:1 fuel
il mix)...
The one GLARING item which I keep going towards is the float and if it is within specs (didn't toy with this when the carb was rebuilt)... eh?
Thanks a bunch!
P.S. how do I figure out what "type" of Tach will work with my OB? I figure this would be a wise investment to be able to fine tune and keep it running tiptop.
Thanks a bunch!
