69 Johnson 40HP - Which coil is top/bottom
newhamburgboating
i found a diagram on here at one point, but didn't bookmark it. any easy answers out there?
Thanks in advance!
boobie
Re: 69 Johnson 40HP - Which coil is top/bottom
The one closest to the carb is the top cylinder. One closest to cylinder head is the bottom.
gm280
Thanks in advance!
After viewing the parts diagram for your engine, I can't seriously tell. You are going to have to see which cylinder is on the compression stroke while the points are starting to open. And then that will be for whichever cylinder it happens to be...
F_R
What boobie said is correct.
