Re: 69 johnson 85hp starting problem
If it has the original control, it doesn't have a neutral switch in the control.
Do you have a multimeter and know how to check voltages? That ends all the guesswork.
You can start at the solenoid and work backwards or start at the key switch. Lets start at the key...do them in order presented
1. Check for voltage at the red/purple wire at the switch. If 12v OK, or if 0V, check the 20 amp fuse near the solenoid.
2. Check for voltage at the white wire when key turned turned to start position. If 12V, OK. If 0V, bad key switch.
3. Go back to the motor and check voltages at the white wires on the solenoid while somebody turns key to start position. Should be 12V on one and 0V on the other. If 12V on both, bad safety switch. If 0V on both, bad wire coming from key switch. If 12V on one and 0V on the other, but no click, bad solenoid.
4. If above tests indicated bad safety switch, double check safety switch. Is the throttle set to "slow"? It won't close the switch if it isn't. If the throttle is set to slow, ground the saftey switch wire. If it cranks now, that verifies that the safety switch is bad.
Hope this helps.
