I put the engine back together after a rebuild, but can't seem to get the armature base to rotate. I noticed that there was an indentation in the retaining support ring (0303277) - does this have to be installed any particular way?
If I tightened the armature support brass plate (0303278) too much, or didn't have enough lube on it, would this cause the armature plate to stick?
