JasonJ
- Joined
- Aug 20, 2001
- 4,163
When I was done for the season last year, I changed my lower unit oil, and it was a bit milky. I told myself I would change the seals the next spring. Well, it is now spring, and I have run it several times. I have a dirt driveway, so when it is sitting on the dirt, I never see any drippage. I now have it on the cement pad in front of my garage, and there is a small puddle of gear oil under the lower unit. The motor is tilted in the trailering position. When it was in my garage for the winter, it was down in the running position, and I did not have any leakage.<br /><br />I am suspecting maybe the shiftshaft seal and/or the water pump seals. I went to Napa the order both, figuring "why not". They not only had nothing in their books on the 68-69 Merc 1250, but they had practically nothing on inline 6s in general. What I need is another source, or equivelant part numbers, or whatever so I can fix this issue before I put it in the water for good. If I am wrong about what may be leaking, I'd like to know that too. From what I can tell, the gear oil is leaking from a hole on the starboard side, the hole looks similar to the water inlet holes, but more forward, near the leading edge of the lower unit. Clams probably know exactly what I am talking about. Any help is appreciated.
