aeronutt29
- Joined
- May 28, 2002
- 112
I pulled the lower unit off to replace the water pump impeller and couldn't remember which way to turn the shift shaft to get it into forward. I found that no matter which way the shaft was turned, the prop shaft ratcheted one way and not the other. This seemed odd to me as I expected the shaft to ratchet the opposite direction when I turned the shift shaft the opposite direction. Also, I couldn't seem to find a middle ground where the prop shaft would spin freely for neutral. In an attempt to get the shift mechanism to switch to the other direction, I applied a bit more pressure to the shift shaft and found that it will turn 360 degrees with a bit of a spring-loaded cam effect. Now, the prop shaft still ratchets one direction, but the drive shaft won't turn either direction. It clunks back and forth about 1/8 inch (about what I would expect to be taken up in gear lash) but will not rotate. My fear is that I've somehow managed to engage both the forward and reverse gears at the same time by rotating the shift shaft past where it is supposed to stop.<br /><br />Anybody have a good guess on what really happened and how to fix it? The shift mechanism worked perfectly before I messed with it.
