69 Mercury 1250 prop question.
Nezlugh
Need to replace prop on 69 Mercury 1250, the only info and numbers I have are 48-65748-17 TAYLER. There is not enough of a true edge on the prop to get a good diameter. Any help crossing this prop would be greatly appreciated.
Thanks in advance!!
steelespike
Re: 69 Mercury 1250 prop question.
Your pitch is 17.
If you have the pitch and look up props for your motor the diameter will follow.
Nezlugh
Thanks, I did a little more theoretical reconstruction and the prop on the motor measures 12-1/2". After looking it up on Iboats I ordered a Solas Amita 3 Blade Aluminum 13.25" dia. X 17" pitch SR.
