i386
- Joined
- Aug 24, 2004
- 3,548
69 Evinrude Ski-Twin 33HP Electric Start
I've recently completed an extensive restoration on a small boat. It's powered by the 33. When I got the boat it was a mess and the motor didn't run. Until recently I had never used this motor before.
What I have done to the motor.
Compression test -> 100PSI on each cyl.
New points (gap .020)& condensers. -> Good, strong, snappy blue spark on both cyls.
New plugs J4C (gap .030)
Rebuilt carb using OMC kit -> clean as a whistle and functioning properly
Link and Sync performed per my Seloc manual.
New impeller -> pumps great, no issues with hot engine whatsoever
Fresh lower unit oil -> Shifts fine.
Initial needle settings: Low Speed 1.5 out / High-Speed .75 out
Plastic gas tank with in-line fuel filter in gas line.
Once the fuel system is fully primed the engine starts and runs with just a quick bump of the starter. Runs and idles smoothly. Doesn't smoke much. Continues to run smoothly while accelerating to WOT. With the throttle control all the way forward I have verified that the throttle plate in the carb is fully horizontal. I have adjusted the high-speed screw while on plane at WOT to the place that gives the most power. In my case it works out to be about .5 turns out. I have no way to measure RPMS at the moment. My manual says it should be making 4500RPM at WOT.
So what's the problem?
The boat is slow to plane and I feel as if the motor wants to give another 10-20%. Also fuel economy seems pretty bad to me. I burned about 4 gallons of gas this morning with about 45mins of WOT running up the river and back. I've trimmed the motor in hole #1, #2, and #3 with hole #1 being closest to the transom. #1 seems to work best though #3 has the anti-cavitation plate in a plane which is closest to parallel to the keel. Also the anti-cavitation plate is 1.75" below the keel. Keeping a 5 gallon bucket full of water up front has shown effective to stop the porpoising.
I'm not sure if I'm having an engine problem, a setup problem, or no problem at all. I thought I'd mention it here since it is using a LOT of gas.
