MickLovin
- Joined
- Feb 18, 2013
- 822
Hi guys, I got a old Chrysler 1978 model 64H8D, it has spark but doesn't start or even suspect to fire. I put br6hs plugs in and checked for spark, which I have, I took apart the carbie to make sure there was no crap in it. I may need new fule though as I am using my spare tank, but I would of thought I would at least get a fire from it. I have a 12.9HP as well, which fires straight away, but it spews exhaust fumes into the cowl and seems to be running hot. So my intentions are to refit the 6hp with the pull cord attachment that I got new for the 12.9hp and anyother bits I can use for the 6hp my only concern is the lack of firing.
Should I pull off the flywheel and check the contacts, I have spark so seems pointless, I am pretty sure it is a fuel problem, if anyone knows of probs with this motor let me know so I can check it out. :blue:
