Mod. E6rcde
hard to start. New spark plugs,did comp.check
k,fresh fuel,so i pulled the air filter box put 3 fingers over carb. Started up then i removed my fingers, engine starts to die.put two fingers back over the carb.runs fine.....removed the carb.cleaned and reused same gaskets,reinstalled ..same thing happen had to cover carb.to start and run w/2 fingers over carb.??? Mabe sucking air past carb.?what do i check next..
