dtg2calvin
- Joined
- Jun 17, 2010
- 8
I have a 1969 Evinrude 6hp. Bought it a couple weeks ago from a guy at work. It had not ran for a few years so I did the basic maintenance (New gas, check carb, impeller, lower unit oil, etc.). I ran it in a barrel at home several times, always started after a pull or two.
I finally took it to the lake the other day. It started in the second pull at the dock. I idled away, opened it up, and took off across the lake. I had never ran it WOT before and nothing seemed wrong. When I got to where I wanted to fish, I idled down and it started to bog down. I tried to rev it back up and it died. After that I could not get it to start.
I had never run it wide open for so long so I speculated that it might be hot. I let it cool down and sure enough, it started. Went to another fishing spot, warmed the motor up, shut it down, and it would not start until it had completely cooled down. I did this 5 times: started easily when cool, ran across the lake, shut down, would not start, allow to cool, repeat.
So the question is, what would cause this? I have yet to change the spark plugs or clean the points. Do either of these cause this? Is it vapor lock?
Thanks
Thanks
