son of a son of a sailor
- Joined
- Apr 15, 2010
- 33
This spring while draining my lower unit I noticed a small amount of water (1-2 oz) drain from the lower unit. Chalked this up to age of the motor and the agesplit case of the lower gear case. After approximately ten outing this year and probably 30 hours, I noticed an oil sludge coming from the weep hole in the lower gear case assembly under the cavitation plate. Seeing as it had been nearly two years since the last over haul of my little old 6hp I decided to tear it down (vs. spending a bunch of money on a new one) and get her back to tip top shape. I dropped the lower unit, and to my surprise it looked like Slimmer had taken a crap onto of my impeler housing.
Knowing I had some issues with seal leakage from my lower unit, I'm trying to pin point the seal that will need to be replaced. I'm assuming the shaft seal (OIL RETAINER Part # 0314167) can be the culprit. The last over haul over two years ago I had saved the HOUSING & RETAINER ASSY. Part# 0382796 as it was not available, and punched out the oil reatainer and replaced it. Was thinking my leak could be under that housing as well. ?????? Any suggestions and reference to other topics and post on here are GREATLY appreciated.
