I have a 1965 Johnson 6HP outboard that starting fouling one cylinder last year. I have replaced both coils, plugs, plug wires, points and condensers. I have also rebuilt the carb and check compression. When I test the spark by pulling the recoil and grounding out the plug, I get a spark. However, for some reason as soon as I put the plug back in and test in the water, the lower cylinder fouls out almost immediately. I am stumped. For some reason the spark isn't strong enough to light the fuel mixture. I have leaned out the premix, used fresh gas and synthetic oil and am not sure what to try next. Any suggestions?
