you need to read the doc a few times....it is tricky
the small springs and dome mushroom caps can drive you crazy by falling down all the time of jumping out of view....:cold:
I found it easier if you actually glue down the springs on their nipple supports with a touch of crazy glue and I also glue down the mushrooms on the springs with a touch of crazy glue
when all done do a blow test air goes inlet to outlet but does not flow outlet to inlet. if it does start over again ...by reading the instructions
"Patience brings joy" :joyous: . ..said the cookie have your daughter rebuild it....for a life long experience
