captain zac
- Joined
- Oct 15, 2007
- 270
I will try to explain the problem if I leave out something please just ask the question and I will try to answer
1995 2855 w/ 7.4 Bravo II carb
When starting the motor it wants to kick into gear
If I push the button on the throttle to disengage the trans. so I can advance the throttle when the engine catches it wants to jump into gear.
This makes it very hard to start when it?s cold and its just not suppose to do that.
Not sure if it is something in the shifter or on the engine
The shifter is about 2 yrs old
About 6 months ago they had the engine out I watched them adjust the linkage using the manual and some sort of special tool.
Not sure if anyone can help but maybe this has happened to someone else
Please feel free to ask any questions because I am sure that I have left out something that could be important in determining the problem
To add I got the engine started yesterday after the temp. of the engine got to 145degrees I was able to rev the engine up and the problem went away
Harry
Harry
