7.4 front motor mounts.
ericcarr2000
Ensign
Quick question I just got done dropping my motor back in my 90 Sundancer it's the typical 454 block. Does anybody have a diagram as to how the front motor mount bolts to the mount on the stringer. I guess my question is, I have a little metal piece where does that go on the mount it looks like it folds down and around a bolt so it stops it from turning somehow? Does that piece go on top or underneath the nut and which nut, there's 2 of them.
Bt Doctur
the lock tab has a section with a small fold, that fold faces up to lock into the motor mount, once alignment is complete a flat ear is bent downward to secure a flat of the bottom nut
Bt Doctur
goes as pictured, that little tab facing up keeps it from turning,
main motor mount bottom, bottom nut, lock tab, upper engine motor mount
