Bt Doctur
- Joined
- Aug 29, 2004
- 19,343
2006 7.4 MPI last run 3 years ago. Fresh batteries. Electric fuel pump does not turn on nor does it have the 2-3 prime mode when key is turned to "On".
All connectors pulled and sprayed. No corrosion issues.Main ign and fuel pump relays swapped and changed. No improvement. Main ign relay clicks. Power indicated using a test light on the Red leads of fuel pump relay.Jumping connectors does run the pump. Checked for any missing grounds in the harness. Green /White from ECM does not indicate a ground to trip fuel pump relay.There is spark coming from the coil.
Suggestions?
Suggestions?
