KnotConnected
- Joined
- Aug 15, 2012
- 221
the Merc manual for my 1994 7.4L Bravo 3 says the idle RMP while in forward gear is 650. Does the idle RPM in Neutral change, or should that be at 650 also? I finally got the boat to idle / run by adjusting the idle speed screw, and its sitting at about 550-600 RPM now while in neutral. The RPMs seem to drop a little as the engine warms up after ~half hour of use, so i'm not sure where to set the idle RPM speed at, as I want to avoid dropping it into gear any higher than 650 RPM, but don't want the engine to die while trying to dock it because it's idling too low after its warmed up.
