N2outboards
- Joined
- Apr 11, 2010
- 87
Just replaced carb seats gaskets on a 7.5 Gamefisher. Still fuel seapage up around the top area around above float bowl area. Acts like it wants to start. Any help here?. Spar plug has fire. Excessive fuel leakage up around carb area.
cheapboatkev, would you mind if I contact you for manual. I'm having the same problem. Do you have any thoughts about what might be causing repetitive fuel pump element failure, bad parts or something with motor?
Thanks
