Wingedwheel
- Joined
- Jun 16, 2009
- 1,071
Hi guys. I had someone drop off a 1983 7.5 Sears gamefisher. Mod# 217-585751 Ser # 38-122003. I've cleaned the carbs and verified its getting fuel. I did a compression check and its around 90psi. So, the problem I'm having is not starting. Its not even trying to fire. With the plug out, I noticed the spark looks weak. I'm picking up a spark tester tomorrow, but if that is the problem, I need to know what I'm looking for. Its a Tecumseh engine and I wonder if perhaps the stator is going or just needs to be cleaned with some sandpaper. In my past experience I found the electrical in these little motors either worked or they didn't. I've never run across one with a weak or degraded spark. Any thoughts or advice?
