7.5 gamefisher
patrickaw21
i have a 7.5 gamefisher by tochusma i think the problem is that it will start fine when you put it behind the boat to start pushing it it bogs down and dies it will keep running for a little bit but then keeps dieing if you play with the primer ball it helps it run a little longer can you tell me what is wrong or what i might need to replace :confused:
Yepblaze
Re: 7.5 gamefisher
At the base of the carburator flange where it mounts against the reed plate, there may be a small rubber thing stuffed in there they call the fuel pump. Pull that out and visually inspect it for a split or tear. They're available from sears parts at the mall or online at the 1-800 number. Have the model number handy when you call.
