Re: 7.5 hp 1976 turning in neutral
Yep, that's normal. As long as it turns slowly. the difference between forward and neutral is the position of the clutch dog. I'm thinking that since the pinion gear is turning both forward and reverse gears all the time, there is some movement of the shaft as a result.
I'm no expert on that, just know it's normal.
JBJ
