Re: 7.5 hp Gamefisher Eska Motor
Woe is me! I just purchased a 15' boat and it came with a 7.5 Gamefisher motor. Motor runs well but a slight problem.....when I put it in gear the prop does NOT turn. Shear pin is intact and in place.
Any info re the type of transmission, how it works, etc will be greatly appreciated. When I place it in gear (Not running) and apply pressure to the gear shift lever and turn the prop, the more pressure I apply I can feel that the prop gets harder to turn, almost as if there is a clutch assembly involved.
Thanks in advance.
Rog
