wbeaton
- Joined
- Jul 30, 2006
- 2,332
I've finally got back to working on my 1974 Mercury 75 7.5 hp. I bought this motor as a runner last winter. I installed a new impeller and tested the motor this spring. The motor pumped lots of water. Too much in fact as water shot out along all the gaskets (exhaust, water jacket and base) and the telltale, but none out the upper exhaust.
I took the powerhead and cowl base off the motor and inspected every passage and port. I could not find any obstructions in the powerhead. A hole in the interior of the exhaust tower leading to the upper exhaust was completely plugged with carbon. I cleaned it out and reassembled everything with new gaskets and torqued to spec. This helped a lot, but it didn't completely solve the problem. I also retightened everything to as tight as I'm comfortable doing. I'm still not getting water out the upper exhaust and water is still leaking around the gaskets, though not nearly as much as before. Water is definately getting through the powerhead and out to the exhaust tower.
Here are a few photos. Maybe someone can help me figure out why its still restricted. I could really use the help. I want to get this thing finished.
