7.5 merc NO water over heating
mauiboy
I have a 7.5 hp merc no tags on what model or sn # it has a blue ad silver cowl strips
my prob is that I changed the water pump and impeller and I still have no water coming out and the motor is getting hot. every thing is installed properly. I blew air in the pee hole and it did not seeamed to be blocked
mauiboy
Re: 7.5 merc NO water over heating
can anyone assist with my prob
58rude
Need too make sure the pump is lined up with tube going to powerhead. Also check the intake screen on the skeg to see if it is clogged. You just have too troubleshoot it. Hard for us to help out, not knowing what year it is etc.
RadarRick
If the intake tube is lined up & screen is not blocked, you should try forcing some water up the tube (from garden hose). the water should flow through the block & out of the tell tale. If it doesn't, you can try pushing weed whacker line up tell-tale tube. Sometimes, crap gets stuck in that tube. You can also remove thermostat & check for water flow there. That's another spot where crud collects and could block flow.
mauiboy
Thaks radar Ill try that not sure where the thromostate is
bktheking
Those 7.5 impellers are small and break, were all the vanes in tact on the old impeller?
mauiboy
Yes brand new Impellar, Thanks Raidar Ill check on that this weekend,
Can anyone tell me how I can find what year and model this motor is. the area that it normaly is has been painted by the prev owener
bktheking
Anyways, the telltale and thermostat have nothing to do with each other, stat can be shot and you still get water coming from the telltale. Those impellers break and the reminants get stuck in the housing and if you don't pay attention and clean them out you will be pumping water into a mess of broken impeller blades stuck in the housing and perhaps in the water tube.
The model is a serial number found on a plate on the transom clamps, sand off the old paint and check for the SN.
