The pee hole on my motor cloggs up. If i clean it out it pees well for a few mintes and then cloggs up again.<br /><br />If I take the rubber hose off the pee hole and let it pee from the hose it runs fine.<br /><br />I was thinking to ignore the pee hole and just let the motor run with the pee running from the hose.<br /><br />But is this ok... or does the pump need the back pressure from the small pee hole ?
