wbeaton
- Joined
- Jul 30, 2006
- 2,332
I replaced the water pump in this motor and found I still wasn't getting circulation. I cleaned out every water passage and port and reassembled everything. I blew air through everything and it seemed fine. I started it up and it pumped fine. Lots of water is pumping out the tell-tale and the exhaust. The problem is that there is also water coming out the spark plugs and from around the exhaust cover. Could this be happening because there is still a slight blockage or that flow is restricted somewhere and is causing too much back pressure?
