Re: 70 horse cylinder scored
Yep, If you take your time, and read the teardown, rebuild procedure a few times before you start.<br /><br /> And make sure to THOROUGHLY CLEAN everything before reassembly.<br /><br /> You should be good to go. <br /><br /> I've done a v-4 , just honing and changing 1 piston.<br /><br /> I've also done complete rebuilds.<br /><br /> If it were mine, being its relatively new. <br /><br /> I would have all three holes bored the same and replace all the bearings. And con-rod bolts.<br /><br /> The extra pistons won't cost that much . And probably about another hundred, or so ,to bore the other two cylinders.<br /><br /><br /> You can get complete rebuild kits. Both OEM, and aftermarket. <br /><br /> <br /> Usually cheaper then buying individual parts.<br /> <br /><br /> You can probably use the old bearings again . I'd be sure to replace, the con-rod bearings . ( crank and piston pin end ) <br /><br /> You'll definately want to rebuild carbs. ( easy )<br /><br /> If you do this , you'll have essentially a new motor. <br /><br /> Whatever you do , when you get this motor going, or get another one. <br /><br /> You need to install a water seperator fuel filter. <br /><br /> It will give peace of mind, and prevent this from happening again.<br /><br /> Good-Luck,<br /><br /> KYHunter
