CaptainHook
- Joined
- Mar 18, 2010
- 310
Ok real quick, 1975 evinrude 70hp had a broken prop shaft. I took a lower unit I had from a 1973 evinrude 70 and installed it. Start it up, put in gear and spins reverse in forward and forward in reverse.
I did not touch shist cables or anything of that sort. Only installs one way, shift rod can only go in one way, I am puzzled. But the throttle does not move very far when you shift it. Could the previous owner have installed new cables wrong in the control box?
They can't be reversed on the motor as one bolts on and one clips on. HELP!!!!
