VAlakeboat
- Joined
- Sep 22, 2009
- 11
Back again for help with some decision making on motor for pontoon project. Restoring 84 harris 280 flote boat, came with 84 johnson 70hp, top cylinder 40 psi, pulled head, cylinder wall looks ok, piston a little beat up on top, ring?? was looking at rebuilding motor then found (craigslist) 1978 evinrude fresh water 70 HP, "low hrs" compression 135 132 135, lower unit good no water in fluid, needs starting fluid to crank, motor had been sitting for several years.Question is how to evaluate the evinrude on the spot, he's asking $550 for the Rude, can't even buy a rebuild kit for the johnson for that, would you take the chance?? The motor is a 100 mile drive and would have to take the day off work to even go look.Thanks for the input
