70 hp Johnson fast idle lever ??
john57
Hello everyone, first time user of the forum. I have a 1993 70 hp johnson 2 stroke that is hard to start cold. I have read the cold start procedure thread posted but I do not find any fast idle adjustment. There is no lever and I do not see any way to pull out the handle for neutral lock. are these standard on controls ? or do you think someone has removed it ? I have only had the boat a couple of months. Starts up easy after I finally do get it started the first time. Cant find the idle lever though. Can anyone help ?? Thanks
Boss Hawg
Re: 70 hp Johnson fast idle lever ??
No idea- my '87 70hp has one-
Mabe post a pic of your control box :confused:
john57
Thanks Boss, you were the only reply. It seems this control has a push button to disengage gears and allow you to move lever forward for cold starts.Tries it this weekend and started right up . I have never had a control like this so I was lost. Finally found the answer in the original boat manual. thanks
