steveo32
- Joined
- Mar 15, 2008
- 60
HI, I am new to the forum and new to boating.
Motor is a 1975 70 hp 3 cyl Johnson Outboard
I bought a motor flush or Muff so I could start the boat to make sure eveything was working. Water comes out the 4 holes that are a couple of inches above the water inlet holes. And water comes out of the pee hole on the top right side of the lower unit. But no water comes out the two exhaust holes on the top back side of the lower unit. Is this because I am using muffs and not actually in a lake? I have seen videos of similar motors running with water comming out those holes. The motor does start and run fine has good throttle reaction and will rev up great. I was just concerned because I don't want to overheat the motor. It is not to hot to touch or anything like that.
Thanks, Steve
Thanks, Steve
