1 have a 92 70 i took of vro pump how do i block off and do i use that as my fuel pump?
H hpshadow Cadet Joined Oct 9, 2009 Messages 13 Oct 10, 2009 #1 1 have a 92 70 i took of vro pump how do i block off and do i use that as my fuel pump?
J Jeff_G Petty Officer 2nd Class Joined May 1, 2005 Messages 179 Oct 10, 2009 #2 Re: 70 hp johnson remove vro pump Leave the VRO pump on, put a plug or hose with a bolt in it to block the oil inlet to the pump and disconnect the wiring harness to the pump.
H hpshadow Cadet Joined Oct 9, 2009 Messages 13 Oct 10, 2009 #3 Re: 70 hp johnson remove vro pump thank you for the help will do
kenmyfam Supreme Mariner Joined Aug 10, 2006 Messages 14,392 Oct 10, 2009 #4 Re: 70 hp johnson remove vro pump And of course pre-mix your fuel and pump the pure gas in the line out before you fire it up.
