hey guys new to forums hope someone can help. i have a 1990 70 hp evinrude. its on a 24' pontoon boat that i purchase couple of weeks ago. it starts and runs good. when in water it dies from neutral to in gear. once u get in gear it runs very nice( i think). when control lever is wot it seems that motor is about 3/4. after some investigation, butterflies are not horizontal at wot. i messed with some adjustments on cam, roller, and throttle cable. something doesnt add up. if u adjust throttle rod on cam and lengthen throttle cable the carbs get close to horizontal, but then idle screw is all the way in an does touch. this is basically my problem. hope this makes some sense. thx
