Re: 70hp 1980 johnson reverse drive
If my guess that it is a counter rotating gear case is correct, it is made to run properly with a counter rotating prop.
If it is a linkage issue as TD mentioned then you need to get the proper linkage or resale and get right case.
As TD mentioned we still do not know exactly what you have, you are just guessing what kind of gearcase you have.
Maybe carry it to someone who knows what to look for and ask a few questions.
If you pull the shift rod up and then turn the drive shaft in the clockwise direction, which way does the prop shaft spin??
Can the guy you bought it from not answer any questions??
just trying to help you figure this out
