I have a 15 year lold 70 HP Evinrude powering a 24' pontoon boat. It starts and runs flawlessly. However, after about ten to fifteen minutes at full throttle the motor dies. I checked the fuel and the ignition system and discovered no spark as the cause for the failure. The engine is not overheating. If I let it sit for a while it will start again and run at speeds for about 10 minutes and then die again. Any idea what may be going on.<br /><br />thanks
