slabs <br /><br />Try adjusting your shift cable at the motor using the trunion nut on the cable. It may be adjusted to far toward reverse and slipping into gear when trying to start the motor.
I believe its a 73or74 , the model # is 70esLl74m, would this also be the reason for it not to crank, also i see fuel coming from the carbs when trying to crank. (thanks for your reply)
