70HP Force Accoustic foam (Fuel Issue)
Neil R
Can anyone tell me what type of foam I need to use when replacing the accoustic foam in the outboard hood. I think it's original foam that isa in it and it's breaking up and causing my stalling problems when WOT hopefully. Sounds like I'm having the same trouble as many others on here stalling or dying at WOT. I cleaned out my carbs and it ran okay for an hour or so and then started dying again, so I think the carb is sucking in dirt, so I'm going to start with cleaning under the engine and replacing the foam.
So any info I can get on what type of foam to use would be great.
Thanks
further
Re: 70HP Force Accoustic foam (Fuel Issue)
If you don't mind the added noise, you don't have to replace it. I removed mine for the same reason and haven't replaced it.
