Drivewayboater2
- Joined
- Aug 21, 2019
- 352
Having a bit of an issue with shifting into neutral. When I throttle down from forward to neutral I must go just a little past neutral to get prop to actually get her out of gear. Seems like a small fix. Question is- Should the adjustment be made on the stainless steel rod adjustment nuts on the connection from the power head to lower unit OR should this adjustment be made with the throttle adjustment inside the power head. Any information would be appreciated .
